  • Replies Replies 914
  • Views Views 238215
thanks for reply also in pm.
installation of ovr & int2 is ok.
it works perfecly.
1x v402 ide board plus special cf adapter
2x 8MB ram board
payment sent
items delivered yesterday
it is correct the installation of the v402 on a500+ like this picture ?
ovr & int2 are ok ?
thanks
The IDE and RAM boards together works great and makes WHDLoad possible. Really slick!
Anyone using the 402 IDE board and the 8MB board together in a 500? When stacked, it's a few mm too tall and the keyboard no longer lays flat in the case. Does the riser board move the stack enough to avoid this? Any suggestions?
BTW, while the 8MB board fits an NTSC 1000, the stacked combination does not. It rubs up against the floppy drive. It needs an offset board like the Kipper2k boards.
Interested in 8meg ram expansion and ide adapter v402 with cf adapter for a500.
Do i need a riser between the adapters?
how much in total with shipping to the netherlnads
I found out that the riser board 'consumes' the headroom it makes, still missing a few mm and touching the keyboard. (A500 case and keyboard, a500+ mainboard)
The riser card might barely work if the ram board were soldered directly to it, saving a socket's height.
So for (standard case) A500, 1000, there is not enough space to fit. I'm going to try with amiga 2000.
During the week i should be getting new ram pcbs that would not need a separator socket.
It should be possible to build an external combination with the external dip-64 adapter to a500 side connector.
Sent a regular e-mail with interested in one CPU offset adapter, and one IDE68K, as they may be available, USA. e-mail matches my name here.
Thanks.
Declaring interest in:
1x v402 with CF adapter
1x 8MB board
1x riser socket
Will send PM.
After some shipping delays, some new pcb for ram will arrive finally tomorrow.
Will reply to interested then.
Blank pcb:s for 68000 offset 5€/pce (5pcs)
4 amiga ps/2 mouse adapters, 15€
Header to connect to other mouse port for wheel
declaring interest on Special ide-cf adapter for v402 for 10 euros, short pin version.
Update : Money sent.
IDE68K 402 and the 68K offset boards arrived - look good and functional (need to do pins/headers) but functional as ordered. Thanks!
AMike, at the moment I have one v402 with boxed(walled) ide connector, but no cf adapter.
I will be able to ship any sold items during next few days, but maybe not for a few weeks after that.
PCB for 68000 riser
PCB for 68000 riser
Pin headers on bottom, upto 3 sockets on top.
The "ground" plane is not connected to any pins by default, so board can be flipped and rotated, and possible ground connection made then.
Place for capacitors and solder bridge connections to ground pins when used in "default" orientation.
Board not tested so far.
Price 6€, shipping 2/3€ europe/world
Interested in one of the ide boards if availiable
Also interested in one of the risers above
Particular one and only ide adapter, v402 available at the moment. Has marks of filing down molten plastic.
The riser card doesnt allow v4x ram boards in the middle.
When at the edge position, v4x ram board would cover middle dil-64 position pads, left row.
