For Sale Useful Amiga Cables & Adapters
  • Thread starter Thread starter a.mi.goun
  • Replies Replies 1576
  • Views Views 227765
Currently the floppy power connector is powering the internal floppy, scsi to Ide bridge, cf adapter, and the DVD drive. If I put the DVD drive at the end it has issues, if I power it early in the chain it works fine.
I want to put the scsi bridge etc inside the miggy and am trying to make the wiring as simple as possible. I can take a picture of the label on the drive if it helps?
Sent from my S7 Edge
I had assumed that as the DVD drive happily runs off the internal floppy power, the external connector would have enough to power it.
Really that is quite a lot things to power from internal floppy port. Hope your PSU is strong enough.
I wanted to point out that ext. floppy port amp in comparition to internal port may be amp limited, that is why I can not assure you it will provide enough power to your DVD. You can try to look in label if the drive lists the power needed. All I can say is I can build the cable, but I can not assure you it will work reliably.
OK - I will check the specs on the drive in a bit.
The PSU is one of the modified PC ones that Amigakit used to do previously, and the floppy traces were reinforced by Bas when he recapped the board last year.
I will get back you with the specs etc.
Cheers
C
Would this be ok do you reckon?
Yes, I can see 5V at 1500mA, that is 7,5WAT at 5V line, I really worry if floppy port could handle this.
OK thanks. I can continue with the current working setup rather than try this. It was just an idea that struck me when I saw something else.
Cheers anyway.
You are welcome and the decision is right. But the idea is nice, but suited for less power hungry devices. Such cable would be useful for devices such as plipbox, more convenient than powering it by external psu.
Added DIN-PS2 adapter to the list of offered adapters.
With this adapter you can connect an old DIN keyboard (such as from A2000 or A3000) to PS2 connector (eg. A4000).
Added PS2 - DIN adapter to the list of offered adapters.
- With this adapter you can connect PS2 keyboard to DIN connector. For example A4000 keyboard to A2000.
Interested in
- 1x Amiga 4-Player Adapter
- 1x Amiga 4000 IDE Terminator
- 1x PS2 - DIN Adapter
PM follows
  1. TRONiC
  2. omar
  3. helgebl
  4. vHDLer
  5. gounderset
  6. Dale423
  7. Xanxi
  8. Cathal
  9. Overmann
  10. Akiko80
  11. pedgaard
  12. Timtheloon
  13. QMadx64
  14. nMAC
  15. neuron55
  16. CCRider
  17. Benzo
  18. paolopal
  19. bdb
  20. neuron55
  21. TommoLB
  22. jaiyenjohn
  23. Peckmore
  24. beej199
  25. dframeli
  26. Jameson
  27. steveed
  28. tramal
  29. DarrenHD
  30. Cbergeman
  31. jkdsteve
  32. G-linx
  33. plaw123
  34. jurassicman
  35. RobertB
  36. Toaster4000
  37. qz3fwd
  38. Overdoc
  39. LordAga
  40. IgorK
  41. Jameson
  42. Dale423
  43. suppah
  44. marchigianluca
  45. Unimatrix
  46. neocdtv
  47. Dege
  48. costner460
  49. captainmoomoo
  50. alama
  51. tommytamsen
  52. hese
  53. CyanPixie
  54. SantiDarkG
  55. Rontti
  56. Rakeim132
  57. kavanoz
  58. cgugl
  59. VoltureX
  60. MrClump
  61. Adam.
  62. Christacean
  63. MrClump
  64. Qix
  65. Stormi
  66. samplist
  67. cv643d
  68. cloverskull
  69. TheNey
  70. gewse2k
  71. DocLeisure
  72. softinn
  73. tramal
  74. chrisgreen
  75. DoctorQ
  76. captainmoomoo
  77. jargo
  78. chrisgreen
  79. costner460
  80. gdaniels215
  81. jrendean
  82. kalkkuna
  83. Disturbed
  84. NorthWay
  85. solipsyta
  86. Akiko80
  87. nickrb
  88. jargo
  89. witchdoctor75
  90. Timtheloon
  91. MaLuKa
  92. Wirerob
  93. DocLeisure
  94. Darby_Crash
  95. Blopztar
  96. bn1029
  97. Raef
  98. Rakeim132
  99. samoht
  100. Nori
  101. amigat
  102. Br0ther
  103. Boing-ball
  104. bedrock
  105. xavlahaye
  106. cyberms
  107. stratos
  108. Darby_Crash
  109. Ariadne24
  110. salaxi54
  111. samoht
  112. Predseda
  113. Ariadne24
  114. Dale423
  115. Boing-ball
  116. jos1970
  117. rhys
  118. Sven1977
  119. utukku
  120. Jameson
  121. cloverskull
  122. XTelefonator
  123. weekendroady
  124. cv643d
  125. vinman
  126. pipper
  127. ferrumm
  128. RandomInexperiencedGuy
  129. bomberoza
  130. Amiga Forever
  131. theq1337
  132. DocLeisure
  133. AwakeningStar
  134. costner460
  135. DiLf
  136. Nek3d
  137. ProfPlum
  138. Haybags4000
  139. St233t
  140. hms
  141. bpa
  142. Oldman1000
  143. lguglielmo
  144. Vasilii
  145. realBruce
  146. PGOAT
  147. jbrianc
  148. Nightshft
  149. HomeLate
  150. mariovieira
  151. Xanxi
  152. VoltureX
  153. tobitt
  154. retrotechtive
  155. utri007
  156. Overmann
  157. Mrsmile
  158. xavlahaye
