A step too far..?
A2Pi for Compute Module
The above is an initial prototype for a Pi Compute Module based A2Pi card. The idea is to have a neater / more flexible / easier to install solution. The A2Pi board carries a microSD card, HDMI port, USB port, the Pi itself, and the A2Pi interface logic.
-Pick a Compute Module of your choice (Pi1 - Pi3 spec)
-Plug said module in to the above card
-Bang the card in to your Apple II and job done...
...well, there's the small matter of a microSD card, and USB hub to add if required
The down sides are:
-Compute Modules are a little more expensive
-The above version of the A2Pi board will be more to produce
-There's only one USB port...
...so a USB hub would be needed. At the end of the day I'm pretty sure standard Pi's hang their USB ports, WiFi, and Ethernet off an on-board USB hub so there shouldn't be a performance hit with the benefit that using an off the shelf hub will be cheaper and more flexible than it being part of the A2Pi board.
What do people think? Is this 'better' or just overcomplicating something that already works fine?
If this is 'better' is the above prototype about right or should it have anything else? eg:
-GPIO headers wouldn't be hard to add but are they needed for this application?
-A boot ROM instead of relying on Floppy /HDD..? (I'd need someone to do the coding!)
-It might be fun to have some kind of composite out / mixing with the Apple II's output for a more 'authentic' experience
